I currently have a 47 inch TV which is mounted onto studs in my wall which is good.
But now I plan to get 70 inch TV which means my existing wall mount frame must move a little upwards to fit above the fireplace.
So, I am thinking to take off the existing screws and drill another set of holes a little above the existing holes.
Is it OK to drill multiple holes in the studs?
What distance will there be between the old and new holes? What size screws does the TV mount use? – Niall C. Dec 26 '13 at 15:27
up vote 3 down vote accepted
Yes. It's OK
Mounting holes do not significantly affect the strength/function of studs (within reason - if you make Swiss cheese out of them, you might manage to have an effect - but that's not what you are describing.) If you are going to be very close (1/4" or less) to the old holes, you may need to drill them out and glue in a dowel before you drill the new holes - if further away, no need.
Thank you...... – Krishna Dec 26 '13 at 16:39
