Someone hit our community's mailbox and trying to get it fixed has become a major nightmare. Basically, when it was hit, the aluminum pedestal was snapped off right at the base. I have an idea on how to fix it, but it involves building a wood pedestal with a 4x4, mounting it to a 4x4 bracket, and then mounting that bracket into the concrete. I've tried removing this base, but these nuts are in really good.
Being that I am the HOA president, it's my duty to find a fix for this ASAP, so I am hoping some of you can assist me here.
Edit: BTW, I called the original manufacturer and they do not make replacement parts for this discontinued 1997 model.
To remove the base from the concrete, heat the nuts with a torch, let cool, heat again and turn while still warm. – Edwin Dec 19 '13 at 17:28
What about calling a welder to repair what you've got rather than trying to replace the broken piece? – mac Dec 19 '13 at 18:49
@mac That's a great idea. I am going to check Angie's List. – oscilatingcretin Dec 19 '13 at 18:54
Does Angie know any welders? Seems like they might travel in different circles. Good luck. – mac Dec 19 '13 at 19:25
Absolutely either repair the base or weld up a replacement. Introducing wood will result in a rickety structure. You will need to get the base off somehow or design a replacement base to work around it because it's impractical to field weld aluminum. Any breeze blows away the shield gas, resulting in lousy welds. – bcworkz Dec 19 '13 at 23:41
up vote 1 down vote accepted
If you know who hit it, buy a new mailbox, and send them the bill. They are liable.
If you don't know who hit it, there's more incentive to save a buck by fixing this one, since most insurance companies will raise your rates if you file for a hit and run, and the raised rates will cost more than just fixing it.
If you can't get the nuts off, either cut them off (if you use a nut-splitter the studs may still be usable) and haul the whole base in to a welder, or have them make a whole new base (the post is pretty thin and may not weld well) and drill holes for new anchors to park it beside the old one.
nut=splitter
Put anti-seize on the new nuts - someone will thank you (or your ghost) the next time this happens.
