My house has a room very humid (85%) and susceptible to temperature changes. Even opening the windows I have mold issues sometimes. The other part of the house is well isolated and acceptable regarding humidity.
Is it best just to isolate this room from the remaining house by keeping its door closed, avoiding air humidity and cold to propagates through the remaining house? Or in other hand would it be better just to keep it open transferring part of this humidity and therefore keeping the average level lower in this room?
Around the room there is the bathroom, street, roof and ground. The humidity is mainly for 2 reasons. 1. Bathroom wall; 2. exterior walls. Most likely the neighbour garden.
We need more details. Why is this room humid? What's next to it on all six sides? – Bryce Dec 17 '13 at 9:13
-1 for wanting to ignore a problem rather than fix it. – BMitch Dec 17 '13 at 13:17
Is this a grow house? – auujay Dec 17 '13 at 15:14
The big problem in a grow house (en.wikipedia.org/wiki/Grow_house) is the humidity that results from it. – auujay Dec 17 '13 at 15:30
If you're unwilling to use a dehumidifier (guess you want a zero-cost fix?) then you need to find the source of the humidity/leak. As @BMitch points out, just being near bathroom walls or having gardens outside does not cause excess humidity. There must be a source of water, and you have to find and eliminate it. Closing off the room will just make things worse, by creating mold and spores that will quickly end up requiring major renovations (replacing all drywall, for example) and it it WILL spread to the rest of the house (via air spaces in the wall, incomplete seal, opening the door, etc). – gregmac Dec 17 '13 at 18:03
Bathroom walls don't create excess humidity unless there's a leak or you aren't running the exhaust vent. The same goes for exterior walls/roof/ground. You need to find the source of the moisture and eliminate it. Trapping the moisture in one room where there's a leak will only make the problem in that room worse. And spreading mold spores throughout the house is only going to make any reaction to them worse.
Thanks. I understand, but this is a short term solution. I need to solve it, but I need to take action in the next few days, and I was just wondering which option would be the best. – nsn Dec 17 '13 at 11:59
The best short term solution is to put a dehumidifier in the room. – BMitch Dec 17 '13 at 12:08
Not an option for now :) – nsn Dec 17 '13 at 12:55
