In my apartment bathroom there's a thick steel pipe with hot water going from the floor beneath through my bathroom and to the store above. There're two pipes welded into that vertical pipe and a towel dryer (actually it's just an U-shaped pipe) connected to them. Each of the pipes to which the towel dryer is connected has a ball cock on it so that the dryer can be shut off.
Now the utility company that services the house tries to threaten me that those ball cocks are unreliable and can break apart at any moment and that will cause flooding my apartment and apartments beneath and I'll be liable for that. The remedy is (of course!) to pay them a fortune for replacing the ball cocks and live happily ever after.
AFAIK there're four major metal alloys used for manufacturing ball cocks and other similar stuff - they are cast iron, brass, bronze and silumin. Cast iron is very rarely used, brass and bronze are used in quality stuff and are quite reliable, silumin is used for cheap imitation stuff and breaks apart easily.
Since I really care I tried to check what those ball cocks are made of. I scratched one of them with a kitchen knife and yellowish surface turned silver, then in about two weeks it turned yellowish again. So I assume that the ball cock is made of brass - yellowish is the typical color for brass parts.
Yet a serviceman from the utility company told me recently that those ball cocks "look like bronze but are made of silumin" and when I told him my findings about the colors change he said "it's emmmm... bronze plus silumin mix". Since brass and bronze look similar I assume he just confuses them and also tries hard to upsell the pricey replacement.
My question is - is it really possible that such "bronze and silumin" mix ever exists and is used for manufacturing a ball cock or is the utility company likely upselling to me?
