I'm pretty new to woodworking and I don't have a lot of tools. I'm working to make pieces to sell and buy more tools as I go. I don't own a table saw, but I do have a radial arm saw. Has anyone ever done tongue and groove cuts with a radial arm on smaller boards? This seems like a bit of a dangerous proposition to me as the saw has not been kind to smaller wood I've tried to cut. If this is not an option, is there an alternative I can use in the meantime of a router purchase?
I used a radial arm saw a lot coming up in the trade, it is a dangerous machine, graduate from it as soon as you can. – Jack Dec 5 '13 at 5:01
@Jack I inherited this saw from my dad who got it from a friend in the early 90's. I was reading up on recalls, and this one is recalled. I called in yesterday and they are sending me a brand new table top and blade guard for free! Hopefully that cures some of the safety concerns. If not, I might retrofit this to a radial arm something or other. :) Thanks for the advice! – Brian Fegter Dec 5 '13 at 21:03
up vote 1 down vote accepted
If you feel brave enough to make the initial cuts through the fence I have illustrated below, that should be the scariest part of the operation.Radial saw Actually the hole in the auxiliary fence can be cut with a jig saw or other means before it is installed. Pardon my rough drawing, I hope it gets the idea across. Once set up it will be safe to use. Finger boards can be added for extra safety. The blade is drawn projecting much farther than needed to make the cuts you need. It is the way the drawing came together. The fence needs to be taller, and the blade only needs to project 1/4" through the fence. The "window" the blade pokes through needs to be made high enough to raise the blade to the highest cut. The table has a raised table added to it so the arbor does not hit the main table, the fence is screwed to the raised table. Use 3/4" plywood for the fence, it is not going to split at a bad time while material is being pushed through. Wax the fence and upper table, it will make the stock much easier to push through.
Make test cuts on same size scraps to gauge the cuts by.
Order of work, before the extra table is assembled, set the saw to cut the shoulders of the tongue portions. All finished cuts will be centered, so if you are using 3/4" thick stock, set blade 1/4" in and a scant 1/4" into the top of the stock. Set up your finger boards, run one side after your test cut is made, flip the piece, run the opposite side. do this with all stock with a few extras.
Next set up the fence I drew earlier set the blade a heavy 1/4" through the fence. Start the cuts for the groove on the other edge of the previous pieces as near to the center as you can eyeball, exact is not important, but get it close. Flip the stock and run it again. You will have a groove started that is perfectly centered. Raise the blade slightly and repeat until you get a 1/4" wide groove. until all stock has been run.
As a reminder, all initial first cuts are done with the test stock first.
Final passes. Raise the blade to get the remainder of the tongue cut, this is a little more critical to cut right the first time. I would actually set the saw at a slight angle, say 1 degree to give the tongue a slight taper, so it will ease the assembly of the pieces.
With the test piece. set the blade so it cuts as close to the 1/4" needed to fit into the grooves cut on the other edge. Run all your stock and make the last adjustment to get it to fit right.
All done!
Note: your results will be better if all stock if flat, straight and uniform in thickness, if not the grooves will change as the wood does, you will be mad at me. Finger boards will help flatten out the stock a little, it will not do it all though.
Good luck
Hi Jack. Just wondering how the blade gets turned horizontal rather than vertical here. I see the concepts, just wondering how this will work with the saw that I have right now. – Brian Fegter Dec 5 '13 at 21:31
You must raise the whole arm pretty high, release the pivot that allows the saw to make bevel cuts, instead of stopping at 45 degrees, go all the way to were the blade is horizontal (parallel) with the deck. I have a 30?? year old craftsman radial arm saw, it does it quite readily. – Jack Dec 5 '13 at 22:19
Wow. I didn't realize it could do that. Your answer is actually the one that helped me use what I currently have. I made a jig to raise the wood up and pass it through. It works really well! With the blade facing opposite me, there's not much of a safety issue with using push blocks. Thanks much! – Brian Fegter Dec 6 '13 at 14:38
I've tried it in a pinch and, yes, it's rather dangerous and stupid. It's just the wrong tool for the job.
Table saws can be found fairly affordably, though. Most big boxes will sell one for around $150. It's not a GREAT saw, but should work for getting some tongues and grooves created.
Great advice here. I chose the other answer because of the accessory port that he pointed out for routing, etc... I'm looking to buy a nice table saw. I'd rather save up a few extra months and buy something really nice. Thanks for your input! – Brian Fegter Dec 5 '13 at 21:27
Some (not all) radial arm saws have a router spindle on the opposite end (may need to get a chuck for it.) My latest "please, take it away, we're selling the house" (I was picking up another, more worthwhile object at the time, and got begged into taking it) Sears RAS has it, under a little red cap, with a label. (not me, nor the exact saw, but shows the same thing) RAS with spindle Never tried using it, as I have a real router. Only goes 6000 rpm, since it's the same spindle the saw is on. Can't find a good picture of one "in use".
OTOH, buying a router is a lot cheaper than a single trip to the emergency room. Several mantras come to mind:
  • Anything that cuts wood cuts flesh.
  • Listen to the little voice that tells you it's probably a bad idea, NOT the one that suggests you can probably get away with this - find a different way.
  • Shortcuts make long delays while you try to figure out how to do things without the appendages you used to have.
If you are OldToolish at all, a plow plane will cut grooves, and you can use two grooves and a spline. Plow plane spline joint You can also cut tongues, but it's more of a pain than two grooves.
Thanks for the in-depth comment. You've enlightened me to the accessory port on the opposite side of the saw. I was blind to this for some reason. I found a very reasonable piece that will most likely work in the interim until I can save up for a router or better saw. Also, I love the hand plows. I've been on the look out for these at antique stores. – Brian Fegter Dec 5 '13 at 21:26
