I work in the apt industry as maintenance, currently on a new property. I had a call this weekend about no power in kitchen outlets or dining room. I found a GFCI outlet in the run, tried resetting it and couldn't. that was with breaker, also a GFCI, in the on position. I changed the GFCI outlet out and when I slipped the breaker to on, it tripped. Then I removed the GFCI outlet, crossed black on black to verify the wiring down the run. All outlets checked out as wired correctly. Any suggestions on next steps?
GFCI receptacles trip for 3 reasons. The receptacle is bad, the wiring is wrong, or there is a ground-fault. – Tester101 Nov 30 '13 at 21:19
There's no reason to have a GFCI outlet on a circuit protected by a GFCI breaker. Replace the GFCI outlet with a standard one. – bcworkz Nov 30 '13 at 21:48
