For re-grouting the bath shower, is there any additional sealing operation (like using sealant) after applying un-sanded grout on it?
up vote 0 down vote accepted
All Portland cement based grout benefit from a sealer. I prefer the distillate based sealers, but I hear good things regarding the newer water based sealers.
One grout type doesn't need any sealer: 2 part epoxy grout. A bit more care and effort during install, but nearly bullet proof afterwards. Shower floors and foyers really stay clean.
I bought POLYBLEND Ceramic Tile Caulk for a small area of re-caulk operation. If I still need to apply waterproof seal on it after my re-caulking, could you recommend one selant? Thanks a lot. – user288609 Nov 27 '13 at 3:28
I prefer the Miracle Sealant line, but TileLab or Aquamix should be adequate. I wish I could point you to a scientific review, but I've only ever seen anecdotal ones (like mine). – HerrBag Nov 29 '13 at 0:58
Herrbag is telling you right, As well as the sealant. Pretty much all the tile subcontractors we use seals the joints with Porous Plus 511 by Miracle Sealant. There is a version that is a color enhancer, and another that leaves the joints the same, please use the latter of the two. Do not leave it on the surface too long, a few minutes only before wiping/buffing it with a dry towel – Jack Dec 3 '13 at 22:45
