Sign up ×
I'm looking for a table of different types of wood, which gives numbers on how bendy they are. Are there any such tables?
I ask because I need to decide which veneer I should use to create tight contours. I'm not necessarily after the most bendy though, as I may make a compromise between bendiness, appearance and cost.
I think the reason I haven't had luck on google is "bendiness" is probably not a technical term. What I really want to know is how small a radius the wood can bend round, for a given thickness of wood, without breaking or splintering etc.
There are lots of such tables. It sounds like you want some combination of bending strength and stiffness information. This should help get you started:… However, you might find what you want faster by searching for something like "best veneer woods". – Wayfaring Stranger Nov 23 '13 at 14:35
To my knowledge, veneers are sufficiently bendy because they are so thin (usually about 1/64"), that its rarely an issue to make a curve. – whatsisname Nov 23 '13 at 17:49
It would help to know what radius you want to bend it to. As info, I recently bent maple paper backed veneer 90 degrees around a vanity corner that had a rounded corner with about a 3/4" radius. The bend is along the grain though, not against it. – getterdun Nov 23 '13 at 20:07
FWIW steamed veneer is less brittle and will wrap a tighter radius, but you need to find a glue that will adhere to wet wood. Perhaps something polyurethane based, which needs moisture to cure. – bcworkz Nov 23 '13 at 23:45
Dry heat works nicely too - read up on "bending the sides" in guitar and violin making. – Ecnerwal Nov 24 '13 at 4:28
