I have a hot tub that is leaking from the pump seal (this was diagnosed by a hot tub tech). They gave me a quote for replacing the pump, which unfortunately is going to require some re-plumbing of the tub since it is an older tub and they apparently don't make/use this specific pump anymore.
However, after a bit of googling it seems that it would be more practical to just replace the pump seal itself rather than the entire pump. Is there some other reason for why I might have to replace the entire pump in this situation?
If the electronics/windings for the motor portion aren't comprised you should be about to rebuild the pump with just replacing seals. Some motors and/or pumps are designed to not allow rebuilds in which case you'd need to replace. – Jason Nov 14 '13 at 17:09
up vote 0 down vote accepted
So, turns out that I was able to replace the pump seal and now everything is working fine. Pretty crazy to think that the hot tub service company was going to charge $1000 for the new pump & plumbing vs. the
protected by Community Mar 25 at 12:00
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
Would you like to answer one of these unanswered questions instead?
