I would like to hang my new television on the wall in the basement, and run the cables through the wall to the entertainment center. My issue, is that the wall is a "half wall" because I have a split level home. So the top half of the wall is fully framed but the bottom half is part cinder block. Now, the bottom half is covered and framed. My issue is, how do I run my wires from the top to the bottom?
up vote 1 down vote accepted
Cinder blocks, like concrete blocks, have voids in the center, hollow areas that make the block lighter while maintaining structural strength. cables can often be routed through these voids.
cinder block
The hardest part might be finding a void. The blocks are staggered in a wall, but the voids still usually line up. You probably need to cut a hole in the drywall just above the top of the block wall. You may be able to see the voids, or you may need to drill test holes through the lower framing plate until you find one.
What happens next depends on where you are routing the wires and what is below the cinder block wall. You can drill through the cinder block at the base of the wall directly below the void and route the wires to either side of the wall. However, if you are routing AC power cables, they must be encased in an electrical box, conduit or metal raceway if they are in a living area.
You may be able to drill a hole directly into the basement area or an unfinished area (crawl space, etc) depending on what is near the wall and where you need to go for power and connection. If drilling in cinder block or concrete, use a masonry drill.
After you finish bringing the wires up into the drywall area, you can patch the access hole you made above the cinder block.
You need to properly mount any cables leading to the back of your TV. Consider a combination box that handles both line voltage and low voltage.
media box
Supplement based on comment
You could put a combination box behind the TV, route the cables in the wall to just above the cinder blocks. Then put another box in the wall at the top of the cinder block. Cover this box with a raceway adapter.
raceway adapter
This box will be a junction box with a blank plate on it, painted to match the wall. Then run a raceway channel down the face of the wall and install another raceway box deep enough for an outlet. If you are running both AC and low voltage, they need to be in approved dual or separate channels and boxes.
You still need to connect to the power at some point, so the raceway channel needs to continue to another conventional junction box.
The voids in a cinder block are probably considered wet (or at least damp) locations, since they are likely at or below grade. You'll probably have to use cables rated for wet/damp locations. Not to mention that drilling holes in them (especially below grade), opens a path for water penetration. – Tester101 Nov 12 '13 at 14:48
Option B? I don't want to drill into my cement :) I've heard of people making a slant from where the cinder block meets the half wall. Something like this. imgur.com/hkHO6TF <- I drew that quickly....Do that or maybe a box... – nkuebelbeck Nov 12 '13 at 14:49
