I need to drill 2 small holes on the underside of my Silestone countertop to secure a new dishwasher. What kind of drill bit can I use?
AFAIK Silestone is some kind of artificial quartz, but I wonder if it's too hard for normal masonry bit.
I need to drill 2 small holes on the underside of my Silestone countertop to secure a new dishwasher. What kind of drill bit can I use? AFAIK Silestone is some kind of artificial quartz, but I wonder if it's too hard for normal masonry bit. |
Silestone is natural quartz aggregate, held together by a polymer binder. I believe it's something like 85% quartz. You'll need a diamond coated bit like this one; it's a tiny hole saw where the rim is covered in diamonds:
It's a bit tricky to start, you need to hold the drill at a slight angle so that only one side of the circumference is grinding, and then as you start to develop a crescent-shaped groove you gradually move your drill perpendicular and continue with the rest of the hole. If you don't do this the thing will walk all over the place since it has no positive center like a regular hole saw. For drilling upside down you'll want a spray bottle with water to keep the surface as wet as possible. That Hitachi bit I linked to has a spiral groove going in the opposite direction of a normal drill bit, which serves to draw water into the hole, which will help you when drilling upside down. Obviously you want to be careful not to drill too far and pop out of the top of your nice counters. For fastening the dishwasher you'll need a plastic anchor into which to run your screws, and I've found this type works great. In a solid material the plastic will extrude around the screw threads and hold really tightly. They do sell them at my Lowe's but I can't find them on their website. The 3/16" size is probably what you need for your dishwasher, and the diamond bit I linked to above is also 3/16". Good luck! |
I had a similar situation and solved it by gluing a strip of wood with the same finish as the cabinets underneath the counter top and securing the dishwasher to it instead. If you have the room underneath your counters for it, this might be something to consider. IIRC, the piece I used was 3/8" high by 1" deep and ran the width of the opening. If you don't have the room, or just want to screw the dishwasher directly to the counter top, this article on How to Drill Holes in Silestone suggests using a diamond-tipped drill bit and a pool of water for lubrication and cooling. Since you'll be drilling on the underside, the lubrication method they describe won't work; I'd suggest drilling in very short bursts, allowing the area to cool between bursts. |
With my granite counter top there are steel plates which have been epoxied to the underside of the granite counter. The dishwasher clips then are bolted into these. When my granite counter top was installed the installers left the plates and the epoxy (since the dishwasher was not there yet) but I am sure you can find the same thing at a hardware store. The other thing to look into is side mounting the dishwasher (I actually have one of the top bolts in use and the other side of my dishwasher is side mounted. This worked the best when I was putting in the dishwasher and allowed me to get it secured with very little movement when it is opened and closed). Also, just noticed these "Granite Grabbers" on Amazon. I have not used them but they might be worth a try.
If you have trouble getting hold of a diamond tip drill, or simply find that far too expensive, you should be able to use a regular glass drill bit for the job. Two precautions are required:
The simplest way to achieve cooling for the bit is to create a circle of putty around he spot to be drilled and fill it with turpentine. |
I used a bit from Menards store like a Home Depot or Lowes. I cut a 1 3/8 hole in Cambria quartz for a faucet. The Brand was Montana MB-65208 diamond tipped bit. I cut at an angle to start then cut straight through by using the pumping motion, Applying water every few seconds. I did a practice and a real cut no problems. Good Luck all. |
