Tell me more ×
My kids and I have spilled superglue onto a Corian countertop in our kitchen, I've heard you can buff out scratches and such from these, but I'd rather avoid scraping and buffing if possible. Is there another way to get superglue off these?
--UPDATE The debonder didn't work, so maybe not CA based glue, will try the razor blade, but has to be when the wife is away...
I'm in the same pickle, wondering what method worked? – user5880 Apr 11 '12 at 18:42
I decided the best policy was to leave it alone as causing any more damage would get me in more trouble. – BlackICE Apr 12 '12 at 13:12
What type of superglue? If it's CA-based, then this debonder will work on it. I'm not sure how it will do on Corian though. My guess is that if the glue didn't react with the countertop, then the debonder won't either. (Mostly I've used it for debonding balsa wood and/or carbon fiber.) I'd definitely try it out on a small scale first, and if it doesn't hurt the countertop, then go for it.
alt text
If that doesn't work, then my next plan of action would be scraping it off and buffing.
Yes, it's a CA glue, I'll give that a shot and update with results. – BlackICE Dec 13 '10 at 14:09
The debonder is simply acetone.
@Joe: True, it's usually about 95% acetone. The problem with acetone is that it evaporates very quickly. Most debonders have additives to lower the volatility of the compound to allow it to work on the surface it's applied to before it evaporates. So acetone could be a good first option, and if it doesn't work, then go with a debonder. – Doresoom Dec 13 '10 at 23:28
Use a new, sharp razor blade and ensure you are parallel to the surface before going in.
@david i read your update, how'd the razor blade go? – allindal Mar 12 '11 at 23:40
