Tell me more ×
I'm looking for an electric water valve for a DIY project. I need to be able to close it partially so as to control the water flow rate. The exact details of how to control it are not important; I'm sure I can build the necessary circuitry.
Could someone please recommend one?
The only valves I find are either huge industrial valves or unbelievably expensive (£500+) lab valves.
Found some valves for approx €80 plus delivery at clippard.com/store/byo_electronic/byo_proportional_valves.asp – romkyns Dec 10 '10 at 18:08
1 Answer
up vote 3 down vote accepted
What you're looking for is called a proportional valve and they're typically not cheap. Here's a series that should do what you want from ASCO, and I was able to find it for sale online for US$316 (as of today). I'm not sure if that price includes the PWM controller module or not, or how necessary that module is.
Hmm, thanks for this. Spent another hour searching knowing the proper name for these valves, and they are indeed expensive (in addition to being rare and hard to find). I think I'm best off grabbing a cheap tap-style valve, a couple of metal gears and a strong stepper motor... – romkyns Dec 10 '10 at 17:48
That would definitely qualify as doing it yourself! – Mike Powell Dec 10 '10 at 18:25
