Tell me more ×
I have a window that slides to the side, and each time temperature outside drops below 0*C it freezes and there is no way to open it (not that there is ice all over it, just moisture from the room freezes somewhere inside I guess). Are there any (easy) solutions to prevent freezing or making it open when needed?
What is the material of the window sash and frame (ie. Vinyl, wood, metal) and is it painted? – ChrisP Dec 6 '10 at 20:21
@ChrisP Looks like a vinyl frame and window (metal wrapped into vinyl?). Not painted. – serg Dec 7 '10 at 0:27
My suggestion would be to pull out the window and clean everything really well to make sure nothing is gumming things up. Then I would use a clean rag and wipe all the areas where the window contacts the frame with a good quality silicone lubricant. A little goes a long way with silicone lubricant, you don't need to saturate things with a direct blast. I would avoid wd-40, or other cheap oil sprays, it could make things worse.
Chris is absolutely right on. Always use a dry silicone spray lube, never an oil based or WD40. This is very common in bathrooms where a lot of condensation forms on the windows. Wipe excessive moisture off the windows and frame whenever possible. – shirlock homes Dec 8 '10 at 8:40
One workaround is to install a heating cable along the perimeter. When you need to open the window you heat it up so it unfreezes.
