What is the best way to cut a 20 inch vine (font) monogram with a circle around it, out of 1/4 inch Baltic birch plywood? I have seen them everywhere but I'm finding it extremely difficult to cut out with my jig saw. Are there better tools and/or techniques available that would make it easier?
What is the specific nature of the problem you're having? Bad edges? Inability to get cuts on the desired lines? – The Evil Greebo Nov 6 '13 at 14:52
The problem is that the thin curvy nature of the monogram takes too long to cut with my jig saw and ends up breaking off. – Valeri Nov 6 '13 at 14:56
Are you asking us to shop for an affordable laser cutting machine for you, or how you can cut the out monograms? – Tester101 Nov 6 '13 at 15:04
A long neck scroll saw is the animal of choice. It uses short strokes and you match the blade type to the material.
Heres a short discussion of the types of scroll saw blades
Much better answer! – The Evil Greebo Nov 6 '13 at 17:13
If you want to save money and space (but not time) over a powered scroll saw, another alternative is to get a jewelers saw or a fret saw. These are essentially coping saws that are smaller and in different shapes. Some have very deep throats that help to access the middle of a large piece. Like with a powered scroll saw, you can take the blade on and off to access and cut fully enclosed holes. This method requires good clamping too, preferably with the board vertical in front of you at about workbench height.
Oh, and be sure to read reviews before you buy. There are many hand-powered tools out there that are worse than worthless, but also plenty of good ones.
