Related to this question, The blinds project has gone pretty smooth up until this point. It seems that some walls have plaster or masonry behind them. Probably not a big deal, but I've snapped a couple of quality drill bits in the process.
Thus, I ask: What should I do to fasten the rest of these to the wall? I have seen some suggestions online about using molly anchors, but I'm not sure if that's the right approach, or even which molly anchor is appropriate.
Plaster generally won't snap drill bits. It's too soft. Masonry, however, will. – The Evil Greebo Nov 5 '13 at 17:00
You know, I thought it might be masonry, but I wasn't sure. Considering these are exterior walls, +1. I'll update the question. – BigHomie Nov 5 '13 at 17:02
up vote 3 down vote accepted
Tools
Hammer Drill
The job will be much easier with a hammer drill, or a drill with a hammer option. Though it can be done using a regular drill, given enough time and patience.
Masonry Bit
You'll also want to put a masonry bit in that hammer drill. A carbide bit is the choice of champions.
Method
Squeeze, Push, and Wait
  • Put the tip of the bit where you want the hole.
  • Squeeze the trigger on the drill motor.
  • Push against the back of the drill motor, or grab the other handle if the drill has an optional side grip.
  • Wait. Hold that position until you've created a hole the proper depth.
Pull Out
Similar to the Squeeze, Push, and Wait. Except that you pull the bit out of the hole from time to time, to clear any dust and debris from the hole.
Worked like a charm. I went with the DeWalt corded hammer drill, as the corded one was cheaper, and a drill bit similar to the one you pictured. I also used masonry anchors as The Evil Greebo suggested, for future readers. – BigHomie Dec 28 '13 at 12:39
Assuming that you have masonry walls, you need masonry drill bits and masonry anchors, which are somewhat different than the molly anchors you find for use with hanging on plaster.
Any masonry anchor style should do - as long as you size it appropriately for the item to be hung.
When reading up on this, some articles mentioned I need an impact drill, is this a requirement, or is a regular drill fine? I have an 18v B&D btw, it get's the job done. – BigHomie Nov 5 '13 at 17:29
For a small job like you're doing you can probably get by with a regular drill. The impact drill does tend to work a little more easily with stone/masonry because stone is more brittle than wood. – The Evil Greebo Nov 5 '13 at 17:32
