I am working to rehabilitate an old chimney for use by a wood stove. There will be approximately 18 ft from the wall chimney socket (this is probably not the correct name for it) to the chimney top on the roof. I plan to situate the stove right next to the socket, so not much exposed vent pipe from the stove to it should be needed.
Which kind of pipe should I use for the liner and for between the stove and the chimney socket? I did this very similar job before but for a radiator boiler and water heater, which both run on gas and for that I used Type B vent pipe that is twist and click. I imagine for wood stove I would need a different type of pipe.
If this is an existing chimney that was built with flue tile, there are stainless steel flex liners available (single wall) for use within the chimney. – Fiasco Labs Oct 28 '13 at 2:48
Why do you think you need a liner? Contrary to the hype I've heard that masonry flues are superior to metal. – Rand Apr 26 '14 at 22:17
@Rand, they are, provided the chinking is all still good inside the flue. Often, it's cheaper and easier to line than it is to rechink. EDIT: Also, in the case of a single-wall masonry chimney, the flue isn't superior at all. – TDHofstetter Aug 24 '14 at 16:41
Check local codes. I suspect triple wall will be needed but may be able to use double wall. Ohio and TN is triple. H-D contractor's desk should be able to tell ya?
I would recommend using a 316Ti Stainless Steel Flexible Chimney Liner for your wood stove. I believe the chimney socket you refereed to is a thimble. The flex liners are generally sold as kits and the connection you would want to use is a Tee connection. The tee connection is comprised of two parts to make the connection through the thimble or socket. You can use single or double wall black stove pipe. Single wall stove pipe must be at least 18 inches from any combustible material, while double wall can be at least 6" away from combustibles. Check out this video, it will explain how to install a stainless steel flex chimney liner.
Self promotion is frowned upon on DIY.SE. If you have any affiliation with Rockford Chimney Supply, you must disclose. – Doresoom Apr 20 '15 at 20:37
