The answering machine is making noise and there is a photovoltaic system connected to the house. What can cause this?
Can you provide more details? How is the PV system hooked up (DIY, grid tie, battery charging...)? Does the answering machine make noise constantly or just during a call? Are the wires close to each other? When did it start? Did anything change? – Henry Jackson Oct 21 '13 at 3:47
Inverter hash? What's the noise sound like? – Fiasco Labs Oct 21 '13 at 6:56
If you disable the solar system (open the breaker) does the noise go away? What brand? What model? How long? Please improve your question. – Bryce Oct 22 '13 at 0:09
Post an audio recording! – Bryce Dec 17 '13 at 9:12
First, you need to verify that the two things are related. A bad phone line can make a noise with no PV system. If the noise is only with the answering system, it could be a defective answering system that would make noise regardless of the PV system. Seeing two things and associating them without determining an actual link can lead to a lot of wasted time debugging things that are not bugs.
Then, you need to observe and report how they are related (noise when the sun shines = MPPT controller - noise all the time = inverter - likewise, noise should stop when you shut those items down even if the sun is shining, etc.)
The cure will probably be adding capacitors and/or inductors to filter the noise, but without isolating what makes the noise, that's a bit hard to speculate further on. For noise on 120/240V power, a surge capacitor (UL listed, of course) also has the handy function of reducing EMI (electromagnetic interference - or noise on your phone line, in this case.) But if the noise is really from a MPPT charge controller, a surge capacitor on the AC side of things won't help much.
It's also worth checking and rechecking all the grounds - both that they are there, and that they are well-connected.
