I want to build a screen out of 5/4 x 4 ipe boards with 1/2" spacing, using some sort of hidden fasteners. All the hidden fastener systems that I was able to find so far are designed for decking, and offer the maximum spacing of 1/4"... Is it possible to use one of these systems, but set the boards wider apart?
Most of the deck brackets are installed board at a time, and the last bracket holds the next board.
The Shadoe Track however is a continuous rail, with conventional screws from below. It can be set at any spacing.
That's interesting, thanks! In my case this screen is on the wall, so there is no easy access from behind. I wonder, how feasible would it be to build sections of it on the ground and then attach to the wall... – user76 Oct 20 '13 at 15:54
