My main panel has been upgraded to 100 amps. I would like to add a subpanel in the garage which would supply:
  • 20 amp Mig welder running on 120 volts, but later upgrade to a larger Mig welder as i am experienced at welding.
  • Large jointer
  • Medium sized table saw, which is 120 volts and 12 amps
  • 4.5 hp portable shop vac
  • A sander
  • Branch circuits for good lighting, and 5 receptacles.
The main run from the 100 amp panel is 37 feet exactly, so what would be the ideal gauge and type of wire to use for feeding the sub-panel?
Is it a good idea to run the wire in metal conduit the whole span, since the feed goes though the basement ceiling and though a concrete wall in the most direct straight-line to the garage?.
I would like to do the job myself as I have seen the sloppy job the so called electrician did with the main panel, which passed hydro's inspection! I have taken and passed an electrical college course at my local college, I have an eye for detail and am a perfectionist.
This answer might be useful. This answer might also help, and This answer too. – Tester101 Oct 16 '13 at 10:16
If you've just upgraded from 60 to 100; and you still have the old panel, you can likely modify the old panel to work as a subpanel. – Tester101 Oct 16 '13 at 13:37
My answer is almost always the same when talking about garage subpanels.
  • 60 ampere double pole breaker in the main panel.
  • 6 AWG copper wire (x4) for a run less than 75ft., 4 AWG copper wire (x4) for runs less than 150ft.
  • 60 ampere panel with 60 ampere main breaker.
Unless you're running a whole bunch of stuff at once, a 60 amp panel should serve you well.
If you're running individual conductors, you'll definitely want to run it through conduit. If you're using a cable assembly, you'll probably only use conduit if you have to. For example, if you have to protect the cable from physical damage, or it will be underground.
Thank you for the info. why 4 runs – Steve K Jul 26 '15 at 20:45
@SteveK, L1 & L2 hot, neutral, and ground – mjohns Jul 26 '15 at 21:17
protected by Community Feb 9 at 16:40
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
Would you like to answer one of these unanswered questions instead?
