As per title, I am building a large wooden shed with large enough doors to be ABLE to get a car in IF required, but not for permanent use a garage.
Under UK planning laws there are slightly differing conditions for these.
So, what would it be considered as? a shed or a garage?!
The distinction is likely based on square footage, but could be based on anything as Henry jackson points out. – Tester101 Oct 15 '13 at 13:54
I doubt its size related, you can buy some massive sheds, FAR bigger than my actual garage. – Digital Lightcraft Oct 15 '13 at 13:59
What UK planning law distinguishes between garages and sheds? The intertubes only tells me about regulations for small detached structures. If it is possible to put a car in it you'll have to build a floor that can support the weight of the car - that seems to be what the regulations are concerned with. – RedGrittyBrick Oct 15 '13 at 14:06
@DarkcatStudios Maybe your garage is actually a shed then? – Tester101 Oct 15 '13 at 14:27
Hmmm... I park my plane in a brick building with a garage door, so surely that type of structure must be a hangar. – Tester101 Oct 15 '13 at 16:26
You'll need to check your local codes. In the US, most building code sections begin with a list of definitions, and I assume it's the same elsewhere. If the difference between a shed and a garage is legally significant then they probably define it. It could be based on size, intended use, access to utilities, proximity to other buildings, access to a driveway, construction technique... really anything your local building regulator has decided.
If this is a structure that might need a permit or inspection, you could also just call the relevant office and ask them.
