When the wooden fence was built, they used metal posts but only filled the 2' hole with one bag of concrete. The posts are leaning at about a 25 degree angle. I want to dig out the hole again, then add another bag of concrete to each post.
My question is, will this work? or do I need to drill holes in the existing concrete and put in a few pieces for rebar to "marry" the new concrete to the old?
How tall is the fence? The holes may not be deep enough. – BMitch Oct 13 '13 at 14:26
The fence is 6 ft tall and the holes are about 30" deep. – Brian Oct 13 '13 at 15:01
I'd recommend going deeper if it's possible. Rule of thumb is 1/3 underground, or 1/2 of the fence height above ground should be below ground. So a 6' tall fence needs 3' underground, which would be 1/3 of a 9' long fence post. – BMitch Oct 13 '13 at 16:00
So your saying that the holes are 30" deep and 2' wide. With one bag of cement thats only 6" of concrete at the bottom of the hole. Thats a very wide hole for a 2" pipe. With all that loose backfill its no surprise the fence is leaning. How deep do you have to dig until you hit the concrete? – Justin K Oct 13 '13 at 16:40
25 degrees, that's huge!
If you go with the concrete method, no need to drill holes, however ...
Quicker and more robust than pouring more cement:
  1. dig out the top 12" inches around each post
  2. attach a 2' length of ground-contact pressure-treated 2x8 to the post a couple inches below grade, using, for example, 5/16" U-bolts if the post is pipe. The 2x8 needs to be eyeball parallel to the fence.
  3. back fill a couple inches at a time, compacting it as you go. Gravel would help, particularly on the lee side relative to prevailing winds or current lean, but is not necessary.
Going deeper per @BMitch would help if done right (it'd certainly help on a new install), but again not necessary assuming they are currently deeper than the frostline.
if the hole is mostly empty, but there is in fact still hole above the concrete, you could just use fence foam.
http://can.sika.com/en/group/News/Sika_Post_Fix.html
it works really well and its moron proof
