I would like to replace my garage lock with a lock face that does not permit opening it from the outside. I don't have a key to it anyway, and right now it's the weakest link of my home security.
I've not been able to find a solution for this, however. Can you recommend any replacement lock faces that are simply plates, without a key hole?
You could squirt the key hole slot full of epoxy. A grey steel filled type like JB-Weld may be suitable. – Michael Karas Oct 7 '13 at 6:41
What about installing a simple deadbolt? – sharptooth Oct 7 '13 at 6:42
if you really only need to be able to operate this from inside the garage door, a simple sliding lock may fit the bill.
lock
they install on the door and the bar slides into a hole on the garage door track.
Works great for ventilation as well. Mount one so the door goes up far enough to create a 4" slot. The upper panel moves in enough to exhaust the hot air, lower pulls in cool. But as a non-reachable lock device, this is inexpensive and effective as long as there's no window within reach to break out. And the hole on the end will take a padlock large enough to not pull through the track slot or 5" bolt with nut through and will prevent even that. And will work better than jury-rigging the standard garage door lock mechanism that sometimes can be really easy to defeat. – Fiasco Labs Oct 8 '13 at 14:54
Easiest solution I know of is to drill a hole in the track large enough to insert a padlock through. With the garage door closed, you want the hole to be close to a roller so there is limited travel of the door.
