Take the 2-minute tour ×
My condo does not seem to be able to heat up. I have an Apollo 5010 unit that makes hot water for showers/tap and to heat the condo. The air feels sorta warm coming out of the vent, but not warm enough it seems to offset the air in the room. The air never seems to turn off and the rooms are cold.
The proper temperature covers a wide range depending on volume and velocity. Your question should be along the lines of why does it not adequately heat my condo and what can I do about it. Sounds like it is either undersized or defective. –  bcworkz Oct 5 '13 at 20:48
