This question already has an answer here:
This is pretty simple but I don't know how to describe it. There's a door that if left open half way it opens all the way by itself. I'm not sure if it's on an angle and gravity is doing it. How do I make it so the door stays where it is and doesn't open all the way? It's on 3 hinges and is on the inside of the building.
marked as duplicate by BMitch Sep 23 '13 at 20:07
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
I too have a similar problem, it's because of the center of gravity of the door, you can poke something between door and the frame as a temporary solution or use door stoppers on both side of the door. – Shathish Sep 23 '13 at 8:19
Your choices are: gravity, air draft, electromagnetic interaction, strong nuclear force, weak nuclear force ... or a paranormal phenomenon. :) – Kaz Sep 23 '13 at 22:09
It is indeed gravity. You can verify this with a accurate level (test your level by putting against the hinge side door jamb, noting the bubble position. Then invert the level (put the opposite face against the jamb and you should get the same bubble offset) The jamb frame is likely canted. Fixing a canted jamb is very involved: removing door, trim casing from both sides, removing shims and reinstalling new ones.
Fortunately, there is a quick-and-dirty fix for doors that are lightly canted: Cause a hinge to bind (slightly). This will allow the door to 'stick' in position. Try this on one hinge at a time (I like to start at the middle (of 3), so that the door stays in place. Remove the hinge pin, remove the door side leaf. Using a adjustable wrench, adjust the wrench to clamp over one loop (of the (still in place) jamb side hinge). Pry that loop a bit out of alignment. Replace the door side leaf and pin (it should be a little tight). Test door. Readjust as needed (too tight or not tight enough) Other loops of the door side hinge can be similarly adjusted.
If your jamb side screws are marginal, (they move while prying) you should replace them with longer ones, especially on the center screw (of the 3). A 2 1/2 inch screw will lock down the hinge to the internal framing.
Alternatively, if you have access to a vice, you can bend one loop of a removed hinge leaf.
Finally, if you have enough door gap at the hinge side and its clear to you which way to tilt the door (from your level check), you can correct its 'lean' by 'tipping' the door back (towards) vertical by bending ALL the loops of the jamb side of the hinge away from the door. This will reduce the door-to-jamb gap. You would typically do this to only a top or bottom hinge (to reverse the tilt)
