I have a pretty new dual-flush toilet whose fill valve suddenly started leaking for no reason. A picture of the toilet is below:
Basically, the toilet flushes normally once the button is pressed. Water flows from the tank into the bowl. However, there is a problem with the fill valve. While water is supposed to refill the tank from the bottom, it instead leaks out through the gaps in the fill valve. (Picture below)
As you can see, water is coming out from the top of the valve and leaking out into the toilet. If I pull the lever up, the leak stops, but once I release the water starts leaking again. For whatever reason the tank never fills and the water keeps leaking forever.
Now, if I turn off the main valve and turn it back on again, the tank fills normally through the bottom. No water leaks through the fill valve. Of coure, the problem repeats if I flush again.
The problem with these new toilets is that there's no information online on how to fix them. Does anyone here know how to stop this leak and make the water go in through the bottom again?
Was there a small plastic hose going from near the top of that cap to that blue overflow pipe? – BMitch Sep 22 '13 at 22:20
Nope thats the water with a slow shutter speed. It's flowing down underneath the lever. – d.free Sep 23 '13 at 0:03
I haven't worked with your flapper design, so maybe it's different, but all the others I've worked on had that hose to fill the toilet back up after flushing. – BMitch Sep 23 '13 at 1:57
When the toilet is continuing to fill, where is the extra water going? Is it reaching the overflow pipe? If so, you may need to adjust the height of the float (or the entire fill valve). – BMitch Sep 23 '13 at 2:04
The extra water seems to be flowing into the tank, but it's flowing really slowly (trickling out of the top of the fill valve). I think that if I wait an hour, the water would slowly rise to the top and raise the cup, therefore stopping the leak. However, I want it to fill normally through the bottom rather than through the fill valve. Here's a more detailed pics of my toilet: bayimg.com/gaplEAAeo – d.free Sep 23 '13 at 15:25
That's a fairly popular fill valve. To open it:
  1. Shutoff the water, you don't want a geyser.
  2. Lift the float to the top position.
  3. While holding up the float, push down on the top cap and twist the cap a quarter turn (I believe counter clockwise).
The cap will then lift off and you can inspect and clean any parts. Before reinstalling the cap, move any small parts to a safe location, get a small cup to place over the top of the valve, and turn on the water supply. This will jet water straight up from the top of the valve and clear out any debris.
Reinstalling the cap is the reverse of the above procedure. Put the parts back, position the cap back on top, lift the float, press down on the cap, and twist.
Note that if cleaning it doesn't work, it's fairly simple to replace this fill valve.
I took the cap off and cleaned it, but I now think that the problem lies elsewhere. The water is leaking out of the cap simply because the pressure pushing up on the cap is very high, and the cap cannot handle that high pressure. However, the high-pressure water should be escaping into the toilet tank and not pushing against the cap. I think that the problem lies with the fact that the water is not entering the tank - but why i don't know. – d.free Sep 23 '13 at 0:34
protected by Community Mar 14 '14 at 3:38
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
