I removed a ceiling fan and capped off both wires but my circuit breaker trips. Is it possible that the fan was in a pathway with some thing else? If so, do I just connect those wires together? There are two white wires and one black wire.
Did you cap them together? – The Evil Greebo Sep 19 '13 at 16:31
It sounds like you capped 2 whites together, which would be logical.
However, you've probably discovered a situation where one of the whites is a switched hot, improperly labeled (i.e. not labeled).
Try putting a cap on each wire by itself.
It's unlikely that putting a break in a circuit would cause a trip. It's the opposite problem, a short that causes a trip.
