I would like to repaint old wooden doors, which were painted in white many years ago. The paint starts to fall off, and underneath there comes out unpainted wood, but otherwise the paint still sticks to the wood.
I suppose that I have to remove the old paint completely before I try to paint the doors in white again. What is the best way to do that?
If the present paint on the doors is indeed sticking very well and the surface finish is conducive to overcoating then I would recommend a process to fill in the peeled out areas with a spackle or drywall mud. Apply one of these materials with a putty knife, let it dry and then lightly sand to get a smooth even surface. Sometimes it is necessary to apply a second coat of the filler.
You can perform some tests of how well the existing paint is adhering to the wood. Near the existing chipped out areas look to see if the nearby edges of paint would easily pop off if picked at with a knife point or other sharp object. You can also use an aggressive tape such as Gorilla Tape and see if a quick removal of the tape would peel away additional paint. If peeling is apparent then you will have to remove the old paint.
If it turns out that you would have to remove the paint completely from the old doors you would likely want to consider the use of paint stripper. This is a jelly like liquid that you apply to the paint with a brush. It will soften the paint so that it can be easily scraped off. It may require several applications of the paint stripper to get all the paint off - especially if there had been multiple coats previously applied. Steel wool can be used to remove softened paint on edges, corners and curved areas where a scraper does not work very well.
Paint stripper is pretty noxious stuff so use in well ventilated area and wear applicable protective gear to keep yourself safe. Stripper can burn your skin and be very harmful to eyes so make sure that the gear includes good rubber gloves and face shield.
Sanding is another method to remove old paint - however if the paint on theses doors is very very old there is a possibility that it is lead bearing paint. If this is the case it is not recommended that you sand the paint at all and consider other alternatives to provide for containment of the lead based paint.
+1 All sounds good except drywall mud. This stuff is pretty soft even after drying. Finish coatings don't add much durability and these could be areas that are fairly easily scratched or chipped. Spackle is much harder, but fairly brittle. Wood filler (thinned down of necessary) would be a pretty good alternative. Epoxy based is even better, but much harder to work with and probably overkill. – bib Sep 16 '13 at 12:55
