I have a deck design where I want stairs coming down perpendicular to the joist starting at the end of the joist. You can see the picture as a generic not to scale drawing of what I mean.
Generic diagram
I had an idea to have the end joist extend past the rim joist. I then want to attach the stair stringer to the very end of the joist. I am going to use USP's concealed stringer hanger.
Stringer Hanger
Am I able to put a stair stringer like this, or is there a different/better way to get the stairs flush with the rim joist?
I might be worried about pulling force the stairs will put on the joist but then I am not entirely sure. How far do the joists overhang from the beam? – maple_shaft Sep 14 '13 at 1:54
the joist cantilever about 6 to 9 inches from the beam. – Michael Sep 18 '13 at 15:06
Just a follow up. I ended up putting the stringer at the end, and made it flush with the top of the deck. I made it so the top stringer only held one deck board (instead of two) so it was narower. I put the railing on the outside of the joist (next to the stair stringer). This allowed me to have the post flush with the stairs and not get messed up there like the answer below. This way I was also able to create a nosing for the top stair (which is often over looked but probably required by code, even if it isn't enforced). – Michael Mar 21 '14 at 19:42
Creating an extra step flush with the top of the deck will make adding stair railing very difficult if not impossible plus it doesnt look professional. Hopefully you have 2x10 floor joists and that will give you 2 inches to work with. In that case I create a ledger for the stringers and attach the 2 end strings to the outside of the stringer I created. If you have smaller than 2x10 you have to make the stringers so it attaches to the back of the floor joist. Double up on the end stringer so the inside stringer can be attached to the face of ledger board/rim board of the deck.outside stringer is just a spacer.
Its kinds of hard to explain without writing a book.
I think I get what you are saying. I thought about doubling up the last stringer but my railing are inside the deck (doing composite railing posts) so it would make the 4x4s for the railings on the landing part a little offset since I had an extra 2x in there. – Michael Sep 18 '13 at 15:09
I know it's just a rough sketch but I don't see any lamination of your end joists for support. Add another joist at each endpoint and overlap them (all three sides). Stringers can be attached with as little as a 1x3 piece of strapping or stringer straps. All the weight is focused on the bottom of the stringer. So your design is ok but add the extra joists.
Depending on what you are using for decking keep in mind your joist spacing. The more people you anticipate having on the deck the closer the joists should be, just in case.
I don't understand where you would add an extra joist. Are you saying double up the joist that the stringers attach to? – Michael Sep 18 '13 at 15:03
