I'm drilling holes in 4"x4"s in order to put magnets in them. The magnets are 1/8" deep and I'd like to install them to be flush with the surface of the wood. All I have is a Ryobi cordless drill and my bit set.
How can I drill only to a certain depth into the wood? Using a drill press would be great, but I don't have the money or the space to house one at this time.
So you want to drill holes that are 1/8" deep such that the magnets seat flush. That shallow depth implies some precision, which will depend on the condition of the bottom of the hole. Even brad-point bits leave a scruffed (in exact bottom), especially in softwoods like your 4x4s. ----- What is the diameter? How many? How far apart? Not knowing the answers, I'm inclined to think a router will be your best tool one way or another, perhaps by routing a few 1/8" deep grooves, each holding several of the magnets. – mike Sep 13 '13 at 22:11
Do you have a Forstner bit that you are using for this? If not, I would highly recommend you acquire one; using one will ensure the bottom of the hole is flat, which you can't do with a standard twist drill bit. – AJMansfield Sep 14 '13 at 0:28
Why does it matter if its too deep, being careful could you not glue them in? Keeping then flush. You can cut a drill bit so it only comes out the chuck to the desired length – Ben Sep 15 '13 at 10:48
Rather than getting the depth perfect, I'd drill the holes a little deep, and then fill with a caulk, putty, or glue that you can squeeze out of the hole as you press in the magnet. Press in the magnet until it's perfectly flush and wipe off the excess when done. – BMitch Sep 15 '13 at 12:32
up vote 25 down vote accepted
Homemade Stops
Wrap a bit of tape around the bit, to mark the desired depth. Then carefully drill your holes, stopping when you've reached the tape.
I've also seen this done with a bit of wire.
WARNING: Wrapping the wire in the wrong direction, can lead to property damage, injury, and death.
Store Bought Stops
Or you could purchase a drill stop.
Which are also available in plastic
Portable Drilling Guide
There are also portable drilling guides available.
I tried one of these and it was total crap, so I wouldn't recommend it. Your mileage may vary though, so give it a try if you like.
Agree with the "total crap" statement about the drilling guide. So much play in the bearing that it was impossible to precisely hit the desired entry point. Freehand was an improvement. – mac Sep 13 '13 at 17:42
for more than a few holes, those are prone to fail, and fail in the wrong way (too deep of a hole). what is needed is a short length of wood, say 1x1, that butts up against the jaws of the chuck and leaves the right amount of drill bit exposed. – mike Sep 13 '13 at 22:17
Some drills include a depth stop in a secondary handle.
Some people drill a hole through a cork from a wine bottle (or similar dowel) and trim it so that it leaves the desired length of drill protruding.
+1 for the wine bottle cork idea. But ... if you have to finish the bottle of wine before you can take the cork I'd recommend putting off the hole drilling till the next day. – Michael Karas Sep 13 '13 at 23:42
+1, I completely forgot about drill motor attached stops. – Tester101 Sep 14 '13 at 12:02
