Sounds like a dumb question so please bear with me.
I have an old integrated dishwasher in my kitchen, bought by the previous owners of the property which I'm planning to replace. Its width measures 58.5cm and there is only a couple of millimetres gap either side within the kitchen units. I believe it's a whirlpool diplomat, but I don't know the model number without taking the door off or pulling it out from the units.
All the dishwashers I can find to buy are at least 59.5cm width. So I'm wondering:
a) do I have a very odd shaped dishwasher?
b) have dishwashers become wider the last few years?
c) are the stated dimensions not the true width? (doubtful unfortunately)
I don't want to order a new dishwasher only to find it won't fit in my kitchen without modifying the units.
Does anyone have an idea about this?
Any idea how old it is? – wallyk Sep 9 '13 at 16:55
The control panel looks very dated and the plastic cultery tray has faded to a creamy colour so at a rough guess I'd say it's more than 6 years, maybe more like 10 – user1207727 Sep 9 '13 at 17:30
up vote 0 down vote accepted
Except for industrial and "true" commercial machines, all dishwashers are meant to go in a 24 inch (60.96 cm) wide opening, so they are usually a little smaller than that.
A quick glance at LG's site shows them all to be 23.75 inches wide by 33 5/8" high by 24 5/8" deep.
I only have experience with two dishwashers (the 10 year old one I replaced 3 years ago and the new one). When I was shopping all standard dishwashers had approximately the same dimensions (plus or minus 1" or 2cm; the dishwashers were sold in the US market), so perhaps the one you're replacing was on the small side. I had to go look at a lot of places to find a dishwasher that would fit (in my case the width wasn't the problem...we put new tile in and most dishwashers were too tall to fit). I don't think a difference of 1cm is enough to consider it oddly shaped; the "specialty" dishwashers (for condos and small kitchens) seemed to have size differences of up to 10cm or more.
As far as the stated dimensions go, they seemed to be very accurate. The knew the one I purchased would be a tight fit and it definitely was (I had to remove the feet on the bottom to fit in in the cabinet). You may want to download the manual/install guides for various dishwashers that you're considering. Usually the top and sides of the tubs are covered with insulation which can be compressed a little as you're fitting it into the cabinet (although you must be careful of any hoses/wires on the sides). The widest part is usually the front part of the tub which flares out to seal with the door.
In my kitchen, the cabinet face and counter top covered a slightly wider/taller hole inside the cabinet. If your layout is the same you may be able shave a few mm off of each side of the cabinet to make it fit.
