In my dining room, I currently have a switch configuration that functions as follows:
  • Switch 1: when toggled, turns light on/off
  • Switch 2: when toggled, turns Switch 1 on/off
Can I have 2 dimmers or 1? If so, would I use 3-way or 1-way? Currently, both switches have 4 wires running to them, each.
Note: House was built in 2013.
By four wires, do you mean black, red, white, and bare, or black, red, blue, white, and bare? – Tester101 Sep 2 '13 at 11:31
Black, black, red, ground – Brian Sep 2 '13 at 13:48
up vote 0 down vote accepted
Lutron makes 3 way switches for this set up that allow dimming. I just installed one set in my basement. One dimmer will be the base and the other talks to it. Here is what I have - Lutron Dimmer Set. With 4 wires running everywhere you should be set to install these.
I am finding that as a STEP 0 to my dimmer installation, I need to resolve the problem of my switch configuration. My research has led me to the conclusion that my initial 3-way switch configuration was wrong. – Brian Sep 2 '13 at 13:50
That is a different question then. You asked how to add dimmers for a switch that controls another. Just ask another question for your current issue. We would just need to know where power is coming for the two switches. – DMoore Sep 2 '13 at 13:53
When I initially asked the question, I didn't know that my original configuration wasn't a best practice and in most cases a mistake. – Brian Sep 2 '13 at 13:56
