Setup
In my current kitchen, I have a semi-decent (yet always inadequate) amount of cabinet space. I would like to add some overhead cabinets over the peninsula. However, being a peninsula, there is no wall to which I could mount or anchor the cabinets.
Restrictions
To make matters more interesting, the ceiling is vaulted, from roughly 8 feet at the lowest point (exterior wall) to 13 feet at the end of the peninsula.
As a further restriction, attic access to most of that portion of the attic is impossible due to the shape of the roof over that section of ceiling.
Question
Do I have any (relatively simple) options as far as installation and mounting? I imagine I could create a wall on the back side of the peninsula, or find a way to mount/hang supports down from the roof joist. Could I mount them (using support beams) on top of the current cabinets? If so, I presume that could get in the way of replacing the countertops down the line (if not done correctly).
