Sign up ×
I've pulled together a few spare parts that i've had laying about for ages now and I finally have a bit of time to try do something with them.
I've got a solar panel which puts out ~22vDC @ ~2Amps when its in decent sunlight, and i've got a 12vDC lead-acid car battery which i pulled out of my old car.
My plan is to hook up the solar panel to charge the battery and to have the system power a small Raspberry Pi computer 24/7 (assuming the battery lasts) which should draw no more than approx 10W.
I've seen some videos which make it look like all you need is a simple inverter and to plug the solar panel straight onto the battery, but I was under the impression you need a charging circuit to make sure you don't damage the battery?
Are there any detailed guides to doing this available or does anyone have any suggestions on how to go about doing this?
This question appears to be off topic, because this is a hobby project not a home improvement project. –  Tester101 Aug 30 '13 at 11:15
Perhaps you could share a home automation project that the computer would be used in, to avoid the dreaded 'Hobby" label –  HerrBag Aug 30 '13 at 20:02
up vote 5 down vote accepted
Since you have an old car battery, the cost of damaging it by overcharging isn't much ($40?) and that would only happen if it got a lot of sun over weeks. A small home solar system might have thousands of dollars of batteries, so standard practice has long been for those to always have charge controllers.
For small systems the cost of a charge controller used to be significant so it was common to forego it in favor of simplicity. However, there are now very - inexpensive - controllers which no longer as easily justify the old practice.
If you can afford an additional $25, you might as well do it right. Also, it would come with instructions on what to do.
Those controllers look great (and idiot proof)! Thanks :) –  NULLZ Aug 30 '13 at 7:33
