So I have an AC unit outside my room onto which a whole bunch of water falls from straight from the gutter. Will this ruin the unit? Also, it makes A LOT of noise. What would be the best way to dampen that?
Water falling on AC
Gutters should direct water to the ground and away from your house, not onto the AC unit. Sounds like yours need cleaning. – BMitch Aug 27 '13 at 17:56
Unfortunatley it's not my property and it is not a matter of cleaning. The thing was designed that way. Can I do anything about it? – ovatsug25 Aug 27 '13 at 18:11
@ovatsug25: Probably no one would mind if the gutter were cleaned and/or repaired. Gutters should not drip. Why do you say "it is not a matter of cleaning"? – wallyk Aug 27 '13 at 18:30
The outdoor units are meant to have water hit them. Only a flood or major major standing water would hurt the unit - unless the water came down at such a high rate that it bent something.
Go outside and look at your unit. It will have a "section" or box with the electrical compontnents. It would basically have to flood to that height to hurt your unit.
Water could have a good impact in that it would cool your unit and clean off dirt and small debris. I can't really see how this would hurt anything.
The power of water has carved grand canyons through the face of the earth over time. While normal rainfall, or an occasional splash won't damage the unit. A steady stream (or drip) in the same place over a long period of time, could potentially cause damage to the unit. – Tester101 May 16 '14 at 14:32
@Tester101 - I have had to replace some capacitors and wiring on units because they had rusted out because of standing water nearby. – DMoore May 16 '14 at 14:42
