[UPDATE: After reading the question and answers, please see this blog that shows how the fireplace renovation was completed.]
I am getting ready to begin tiling part of my fireplace. The current finish is a wooden mantle surrounding a masonry façade that runs to the outside edge of the firebox.
This is the current appearance.
fireplace wide
I plan to place ceramic tiles over the masonry portion of the façade. I will probably use stoneware tiles (in an arts and crafts style), either 4x4 or 8x8 for the bulk of the field, possibly with decorative tiles in the corners. (I realize I will have to cut tile, use other sizes, use border tiles, or adjust the moldings to deal with the slightly wider upper field.) I will also check with the manufacturer/supplier to ensure that they are suitable for fireplace installation.
The surface of the masonry façade appears to be a cement-like finish that has been trowelled to look like brick. Here is a close-up.
fireplace mid
The surface seems very solid ith no areas breaking away except for minimal chipping in a few places at the very edge. The surface also seems to be painted. There is no significant flaking or loose paint. See below.
fireplace close
I am not sure what is below the cement-like surface. I suspect brick, but am not certain. The fireplace was built around 1905 and possible renovated in 1999, but I am not certain.
My questions are about installation:
1. Do I have to remove the cement surface before tiling?
2. Do I have to strip the paint?
3. What mortar, mastic, adhesive or thinset should be used to hold the tiles?
Obviously, I would like to minimize the prep work but want a strong adhesion.
Really nice mantle. What are you doing with the door or opening? Also are you tiling the base? – DMoore Aug 27 '13 at 15:43
@DMoore Undecided about the opening. I know doors are much more efficient, but use is occasional and the ambiance of the newer doors jars a bit with the tone of the house. The base tiles will probably stay the same (even though they are painted and a bit splotchy (1869/1905/1999/now eclectic mix). I am comfortable with the new tiles sitting proud of the screen attachment points. – bib Aug 27 '13 at 15:54
Are you sure that's not just painted brick? – DA01 Aug 28 '13 at 3:21
It's definitely not. One give away is the varied angle on the sides and ends, not really achievable without bizarre cutting of brick. On close look, it is clearly a trowelled on surface that has been decorated. – bib Aug 28 '13 at 11:08
up vote 4 down vote accepted
Cement surface and even paint (scarifed with 50 grit belt sander or similar) can stay, if both are well adhered..
An experiment is in order:
Observe the removed thinset:
  1. If it cleaves off with no embedded paint, paint is very well adhered, but may be too slick, scarify through paint layer to cement before tiling.
  2. If some paint embeds, and some thinset remains on surface, it is a good interface layer, proceed with tiling.
  3. If paint cleaves off easily, remove paint fairly thoroughly before tiling.
In no case use a premix mastic thinset or other adhesive to adhere tile.
As soon as we pick out tiles and are ready to start, I will try your protocol. Sounds right. Thanks – bib Sep 3 '13 at 2:11
