I want to attach a 2x12 ledger to my house, but looking at the rim joist of the house it seems to be a 2x10 sitting on two 2x sill plates.
Is it a problem attaching the 2x12 ledger to the 2x10 house rim joist?
The size doesn't matter but the exchange from your house does. – DMoore Aug 27 '13 at 1:04
No problem doing this. Make sure that you attach it in an appropriate manner. The preferred approach is to use a special deck tie (Simpson makes them) that uses a thick rod to connect a deck joist to a house joist. If that's not practical, using lag bolts in an alternating pattern. Most permitting authorities have specific guidance on what they want to see here.
By code you need both. 2 tension bolts are required. Its been code for awhile but inspectors in my area are now requiring it. – Justin K Feb 23 '14 at 17:09
I'm not an engineer, but it should be no problem. Be sure to lag screw or thru bolt it to the rim. Do not use nails except as a temporary hold up. Use joint hangers on the ledger... these are often easier to install before it goes on the wall.
Also ensure you flash the top of it with Z flashing tucked up under the siding and over the ledger. You don't want water getting behind the ledger and rotting out the connection.
