I have a slate kitchen floor and wooden skirting on the walls around (no beading). At some points around the wall there are gaps of around 4 mm or more.
I was thinking of simply stuffing paper in the gap and then using polyfilla to cover the gap (sanding it off and then re-painting the skirting).
Does this sound like a good idea? I am worried about making a mess of the slate floor using polyfilla.
Is your floor uneven or your skirt/trim too high? Are you trying to fix it or cover it up? – Jason Aug 21 '13 at 16:42
The floor is uneven. Basically I just want to seal the gap to prevent insects coming in and keeping the warmth in. – Carl Owens Aug 21 '13 at 16:50
If bugs and cold air are coming in through this gap, you have bigger problems. Trim is simply used to cover a junction between two different planes, where a gap or ugliness may exist. Trim should have nothing to do with the seal of a building. – Tester101 Aug 21 '13 at 16:54
up vote 2 down vote accepted
I would use foam backer rod in the gaps, put down masking tape on the slate (and perhaps above the joint, on the skirting and fill with the polyfila or perhaps a colour matched latex based caulk.
Pull the masking tape right after smoothing the joint down with a finger.
