In troubleshooting a problem with recurring flushing (turned out to be a worn out flapper) I lowered the tank water level to about an inch below what the manufacturer marked as the waterline. Flushing seems to work fine - plenty of force, refills, fine and the flapper is fixed. I'd like to conserve water by leaving the water line where it is now, but will I be causing some kind of problem if I do?
As a volume reducer, people have put two or three bricks in the tank to conserve on the quantity of water used per flush.
Being down by 1 inch of head on the water level isn't much to worry about.
As long as it flushes the contents either way, you're fine.
Someone used some drink bottles filled with water in mine, and attached them with rubber bands. Worked well enough until the one of the rubber bands broke while I was away and the bottle hung up the float preventing it from filling, and I got a frantic/confused text from my wife to the effect of "Eww! Someone left a strawberry milkshake in the back of our toilet and now the toilet is broken! Help!" – gregmac Aug 19 '13 at 17:02
Heh, rubber bands have a way of doing that. – Fiasco Labs Aug 19 '13 at 21:38
