I have these two faucets in the kitchen that I'll use for a washing machine and a dishwasher. Alas, the handles seem to be broken:
I guess I should change the handle at some point, but right now I'd be happy to leave it open using a wrench.
I'm unfamiliar with the nomenclature of these things, but going by this legend it seems like I should be able to rotate the stem -- that's the outer brass thingie right? -- with a wrench to open it.
I've rotated it a bit but no water came out. I'm afraid I'll be disassembling the whole thing if I rotate it too much, so any advice would be rather welcome!
That is the stem, but looking at your pictures it appears the faucets are 1/4 turns. So if you can turn it more that 1/4 of a turn and not get water, you need to turn it the other way. If the other way doesn't work you'll need to replace it, because that's all the knob/handle would do. You may have loosened it and need to turn it back to where it was to start. Guessing from photo on the 1/4 turn, if they aren't you may need to just turn more or try the other way. – Jason Aug 14 '13 at 21:45
That worked! Thanks a lot. Not sure how to determine what angle yields the most water flow but I think I'll manage something. The washer seems to take longer to fill up than I was used to, but that might because (a) I'm paying too much attention to it and (b) this house has lower water pressure than usual for me. – Luís Oliveira Aug 14 '13 at 22:03
You can also remove the screw holding down the other handle and use the same handle on both. – Jason Aug 14 '13 at 22:16
Be careful when using a wrench not to round over the corners of the stem; too much of that will make it even harder to turn and make a replacement handle fit poorly. – Kevin Reid Aug 15 '13 at 2:41
@Jason - you should convert your comment to an answer. – bcworkz Aug 15 '13 at 20:56
up vote 1 down vote accepted
As mentioned in the question comments, the first suggestion was spot on. Regarding the second suggestion, both handles are broken. Thanks again! – Luís Oliveira Aug 19 '13 at 16:54
