Some of my taps were dripping slightly and it was recommended that I test the water pressure. After a few tests the pressure is 140 PSI in the house, which I understand is extremely high and I have been advised that the water pressure reducing valve (WPRV) needs to be replaced. I am not a plumber, but have sweated a number of joins in the past and can fix most basic things. However, after looking at where the valve is positioned I'm a little nervous to attempt this kind of repair. It seems relatively straightforward, but the risk of failure could be great (and expensive) if things go wrong.
  1. First of all, would it be confirmed that the valve is toast? Are there any adjustments that can be made - perhaps it is just the settings? Or am I dreaming?
  2. The valve is immediately below the water meter (see pic) and is threaded directly onto the pipe. The issue is that the valve is against a wall, so I can't (seemingly) turn the valve to unscrew it. Can the top of the valve (the bell shape) be removed and replaced, or should the entire valve be replaced?
  3. Am I messing with something above my experience level and should I rather be spending $200 (excluding parts) to have this replaced by a plumber?
Water Pressure Reducing Valve
What is the range listed on the yellow tab on the PRV? Have you tried adjusting the pressure by turning the adjustment screw out? – pdd Aug 11 '13 at 22:35
If you cannot adjust the pressure, the bell cap does come off to aid removal and installation. I've no idea if replacing just the internals is possible or if problem can be in the valve body itself. I just know how to take things apart. (Occasionally I can even reassemble things :) ) – bcworkz Aug 12 '13 at 1:34
At 140 psi, either that valve is shot, or you need to install/check your expansion tank. To know for sure, after running some water for a second, stop any running water and check your pressure again. If the high pressure only occurs after the hot water tank has been heating back up, then what you really need an expansion tank.
To replace this valve, after turning off the water, unscrew the union fitting on the bottom of the PRV (at least I'm hoping that's a union, it should be two pieces and the nut should move independently from the pipe). You should be able to work on that with a crescent wrench one partial turn at a time. Then with that disconnected, you should have some play in the pipes to pull it slightly out from the wall and unscrew the valve from the top threaded connection. Installing the new valve will be a similar procedure in reverse, just clean off the threads and apply some pipe dope to the male threads first.
