Drilling holes (for curtains) in the ceiling of the 1st floor(2nd floor in the US) of my house I ran into a steel rod in the middle, running parallel to the outer wall. The steel is about 2.5cm in and starts one meter from the side wall. So far, it's at least a meter long. (I drilled three holes and all three hit it.)
Is this a rod and how thick is it? Can I assume that I can drill a few centimeters to either side and not hit it?
(I'm assuming that I can't/shouldn't try drilling through it)
(This is in the Netherlands and the house is from 1985 if it matters)
It's either a) rebar, which is something you probably don't want to drill through, but likely won't destroy the structure or b) it's prestressed/pretensioned concrete, in which case it's a rod or cable under immense tension and cutting through it will potentially cause catastrophic structural issues. – DA01 Aug 5 '13 at 16:51
@DA01 any idea how thick either of these would be? – Alex Aug 5 '13 at 16:58
I think it can vary wildly depending on the structure. – DA01 Aug 5 '13 at 17:03
maybe to clarify. The metal doesn't seem to be there 10cm from either side of the room. I drilled those two hole 1st to 4.5cm, tied a string between them and started drilling along that line. the next 2 holes from the one side also didn't hit the metal and the 3rd one did. – Alex Aug 5 '13 at 18:50
It's a piece of metal that sits on top the window sills to either side(10cm) and into the room about 5cm.
I ended up just drilling another hole 2 cm out from the original holes and it wasn't there.
I guess it's something to keep the weight off of the window frame.
