Take the 2-minute tour ×
I need a glass cutter that can cut up to 1/2" inch plate glass. I heard the cutter's hone angle is very important, but I'm not sure what does that mean. Does 120 degrees better than 140 or the other way around.
I search through Amazon and eBay for this cutter but couldn't find any reputable ones. Can anyone recommend one from real word experience? I won't be doing a lot of projects with it but I definitely want to get a good one and use it for long long time.
My first use for this cutter will be to cut off 3 inches on a 70" x 42" x 1/2" table top along the short side.
You need to be certain it's not tempered glass which cannot be cut. –  bib Aug 4 '13 at 2:16
Yes, it's not tempered because one of the corners is broken and the edge is very sharp. –  Ray Cheng Aug 4 '13 at 3:27
up vote 1 down vote accepted
Glass Cutting
It's not uncommon for thicker glass be annealed, not tempered, for a table top. This is due to the amount of force required to break it.
From what I've been told growing up around a glass shop and working in the industry for a number of years, the reason glass cutters work is that glass, stone, etc will always break at the greatest point of stress.
When you apply pressure to the surface of the glass with a glass cutter you are crushing the surface under the wheel which causes heat. Oiling the wheel on your glass cutter will help maintain this heat evenly for a longer period of time. You need to break the glass along your score before it cools in order to get the most reliable break.
Thick glass, 1/2" and greater is very difficult to cut even for the very experienced. It also takes a much greater force to break after scored. If this is your first attempt at cutting glass I would recommend getting a few scrap pieces of thinner material and practicing on those to get the feel for scoring and breaking the glass. The thicker the glass the harder it becomes to cut off a small amount. Even 3/8" can commonly break roughly and required a belt sander to polish the edge smooth. Breaking 3" from a 1/2" thick piece of glass will be difficult and I would personally opt for a wet saw.
Also, any time you cut glass the edges will become sharp. Be sure to use sandpaper to smooth the edges, called a seam, in order to help prevent cuts.
Glass Cutters
As far as cutter brands, I prefer Silberschnitt because the brass has a nice weight to it and I've grown accustomed to it. Fletcher is probably the most common brand I've seen from shop to shop. Someone that cuts glass daily is more likely to go with a cutter that is self oiling and is filled in the end.
The cheaper "hobby" cutters do the job just as well. The most important thing is the wheel. A carbide wheel will last you longer, but for limited usage a steel wheel will suffice. If you opt for one of these types of cutters be sure to rub 3-in-1 oil on the wheel prior to scoring the glass.
A hone angle of 140° is the most common. After enough experience 140° is easy enough to turn when needed, but broad enough to be effective for 1/4" or 3/8". I've used it for glass with a thickness up to 3/8". A hone angle of 154° is what is used more commonly for greater thicknesses. This angle will give a broader score allowing for more surface stress distributed along the same line allowing for a more reliable break. A 120° angle is more often used in artwork and difficult pattern cuts. A more acute angle is easier to work with and what you want majority of the time. The greater angle is more difficult to work with but necessary to control a break on thicker glass.
The score is a stress riser, glass breaks by fracture propagation from the bottom of the score and water dampening the score can cause the propagation rate to increase significantly due to a molecular debonding effect. –  Fiasco Labs Jun 28 '14 at 17:51
@FiascoLabs I was always curious of the science behind it. What is a general term I can search to research the physics of it? –  Steve Buzonas Jun 30 '14 at 21:17
"glass fracture propagation" would be a good place to start. The best I read was an article "The Fracturing of Glass" in Scientific American Journal Volume 257, Issue 6. Unfortunately, I don't have access to their website to verify if this was the exact article. –  Fiasco Labs Jun 30 '14 at 21:35
