I've been living in my home for 28 years. It's brick on a cement foundation built in 1985. I had a patio poured at the back door in 1986. There is a approx. 1/16 inch crack that I should have sealed where the patio meets the brick but I never did and it has never been a problem. For the last week water has been seeping from the crack in a couple of areas close to each other enough to saturate an area of approx 3 ft. x 7 ft. This area has been constantly wet for a week now. Dont know if this is related but about a month ago the water pressure in my shower slowly decreased, got new shower head and had fair pressure for about a week and now it seem to be decreasing again. Checked water meter and it shows no water leaking when no water is being used. The shower is on the opposite side of the leak, and the ground is not wet anywhere else around the house. Can someone please tell me what this is?
Do you mean water is seeping into the basement on inside of the foundation wall, or water is seeping up through the crack onto the patio? Do you have standing water on the patio? A picture would help. (I doubt your water pressure issues are related, especially since you don't seem to have any leaks.) – Henry Jackson Aug 1 '13 at 22:48
I dont have a basement, the water is seeping up through the crack onto the patio. Yes, I have standing water on the patio. At times it is just a large wet spot from the wall to about 7 ft out and sometimes there are 3 or 4 puddle streams coming from the crack. The water is very clear with no odor. Thanks for your help! – sam Aug 1 '13 at 23:23
up vote 0 down vote accepted
OK, the water must be coming from somewhere:
  1. Water from a leak. If you've been checking your meter and don't think you have any leaks inside that's good, but it's possible there is a crack or break in service line upstream of your meter. This might actually explain reduced water pressure in the house. If you suspect this is the problem I would call your water company and have them take a look.
  2. Rainwater. If the water appears only during and shortly after a storm, then you probably have a drainage problem. Make sure all gutters are directed away from the house. You might also look at grading near the house to make sure water will flow away from the house. Is the porch at the bottom of a slope towards the house?
  3. Groundwater. I would be a little surprised if this were groundwater welling up, but it's not impossible. Have you had a very wet spring that would've raised the water table level? Or done any serious landscaping / excavation / compacting in your area?
  4. Septic system. An unhappy septic system can cause water to well up, although probably not so close to the house or clear / odorless. Do you have a septic system?
(I wouldn't beat yourself up too much about not sealing that gap. If water is pooling from below I doubt a little sealant would hold it off for long.)
I do have a septic tank approx 50 ft or so from the house. There is a slope towards the house but it is about 20 ft from the end of the porch which is 18ft. I dont think we've had enough rain for this to be groundwater, but like you said its not impossible. Also i have not done any landscaping or compacting. I'm a little worried that even though the water meter shows no water leaking/running somehow this is going to be a very costly leak for me. So, I will take your advice and call the water co. – sam Aug 2 '13 at 7:00
protected by Community Apr 14 '14 at 23:38
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
