Tell me more ×
As my family grows (birth) and shrinks (adulthood), and as kids' needs change (puberty) I'd like to be able to change the floor plan to match.
Conventional 2x4 studs + drywall is a bit messy to move.
Is there an alternate way to build walls that are easier to move?
(One idea was 2x4 studs + 1/4" plywood held with screws. Maybe a urethane finish.)
Are going to run all your electrical and plumbing only through the exterior walls? – aphoria Nov 21 '10 at 13:42
I've seen manufactured ones for use in offices, but there's different fire codes for home vs. offices, so I don't know they'd necessarily be allowed. In those cases, a track was mounted to the floor & ceiling, then the wall panels and doorways were installed.
the panels were fairly lightweight (I'm guessing, they used metal studs, insulation for sound dampening, and possibly lauan or other thin plywood. Some of the others were just large window segments.
I also remember hearing of a company in um ... Norway / Sweden, some Scandinavian country, where they had a mostly pre-fab house design w/ all load on the exterior walls, and some way of re-arranging interior walls. I found "A House for all Seasons", an article in a 1990s Popular Science that describes something similar. One thing they mention is that the wall panels are relatively narrow, which likely cuts down on weight, so they can be easily re-arranged. (and they're using drywall, it said).
If I were doing it, I'd do :
  1. attach a 2x4 to the ceiling and floor where I wanted the wall to be. (and if it wasn't on an outside corner, leaving enough space for one section out, likely where they doorway was to be).
  2. Make a series of panels with plywood sheeting, extending about 1 to 1.25" past the base of the wall at the top and bottom.
  3. Slide the sections into place, then screw the wall sections at the top & bottom into the 2x4s.
  4. Install the doorway (although I'm not 100% sure how to secure it).
  5. Install baseboards & crown molding to hide the gaps at the top & bottom.
  6. Cover & seal the gaps between panels with battens.
... although, I'm not even sure if it's legal due to fire codes. (there might be issue with using plywood for walls, particularly in a bedroom).
If you needed electrical in the wall ... I'd probably go low, instead of high, and build a long chase first, then drop the wall sections on top of it. (I don't know if there's any codes to keep you from having all outlets being inches from the ground; they allow 'em in the floor, so I'd think it would be okay).
... and that makes me think ... another good place to break the wall would be at chair-rail height, if you wanted to cut down on the weight of panels, as you could hide that seam, but I'd be worried about keeping it rigid at that point so the whole wall doesn't flex.
update : and I'm assuming this is for bedrooms only, not wet walls.
i'm intrigued by some of your questions, like this one and the conduit one. Are you building a new house or designing one for future construction? Commercial modular wall systems are very expensive and use specialized connectors for electrical, data etc. I have never seen it used in residential construction. I'm not positive, but I don't think portable walls are even included in the new IRC. Floor receptacles are no longer used in residential except for dedicated single appliance circuits, never for duplex convenience receptacles. Minimum spacing is 16 feet or being no more than 8 linear wall feet from a receptacle. This alone makes movable walls difficult to use. Become good friends with your local building inspector. His guidance may save you a lot of trouble. I appreciate your forward thinking, but be careful, very unconventional construction techniques often limit your resale potential and adversely effect your home's value. Looking forward to your next question.
I'm designing a house for future construction. As a novice designer, I want to hedge my bets. As a techno-geek, I want to install Super-Cat9-whatever when it gets invented. – Jay Bazuzi Nov 29 '10 at 2:33
