My local hardware store stocks 15mm diameter galvanised pipe fittings and lengths of galvanised pipe with threaded ends. The annoying thing is they charge $7 for a 100mm length of pipe but $16 for a 900mm length. I bought a 900mm length thinking I'd get a die set and cut and thread my own lengths.
The hardware store didn't stock and dies big enough for 15mm pipe. I've spent the last two evenings searching around for a pipe threading set with a die for 15mm pipe but can't seem to find such an item. Most of the dies I've come across are in inches rather than mm which I suspect won't work with the fittings I've got.
Can anyone give me any pointers as to whether a pipe threading tool for 15mm diameter pipe really is that exotic or where such beasties are likely to be found?
Is 15mm the inner or outer diameter? Dies are sold by OD, but pipe is often measured in ID. McMaster-Carr lists metric dies, but only in even mm sizes from 10 to 24mm. They also have dies for pipe, but not in metric. – Joe Jul 31 '13 at 14:47
15mm is the metric equivalent of 1/2 inch nominal pipe size. I've no way to be sure, but I believe you need a 1/2" BSPT (British Standard Pipe - Tapered) die. – bcworkz Jul 31 '13 at 19:48
15mm is the inner diameter. The outer diameter is 20mm. 3/4 inch is close to 20mm so maybe I should bite the bullet and look for a 3/4" die. – sipwiz Aug 1 '13 at 10:19
