When installing a water powered back-up sump pump can the discharge of the water-powered back-up sump pump be connected by a Y to the discharge of the primary sump pump? I read that it shouldn't according to the Uniform Plumbing Codes and IAPMO PS119. Also what is the proper distance between the back up sump pump float and the primary?
You "can" do anything, but the entire point of a backup system is in the event the primary fails. What would happen if the primary discharge tube gets clogged or otherwise prevents discharge? Codes/guidelines are usually there for a reason, even if they can be annoying. – Jacob S Jul 30 '13 at 19:02
Put check valves on both discharge lines upstream of any "Y" connection to prevent back feeding through the unused pump.
