The image is outside of my house where the down drain leads away from the house. The water flows in the direction of the arrows, and leak occurs where the "T" connector connects to the outlet. I tried pushing the T-connector into the outlet more, but it didn't help.
Downspout leak
up vote 3 down vote accepted
This type of pipe and fitting is meant for burial and is not made to seal. The pop-together fittings just ensure the pipe stays together, not leak free.
If you want water tight sealing on the joints, you need to use PVC thinwall sewer/gutter drain pipe. It will have the same adapters so you can get a proper water-tight seal for the sump pump drain, a nice rectangular adapter for the downspout and glue-together slip fittings that can be cement welded for permanent leak-free operation.
Barring that, you could try popping the connection back apart, get some poly-foam backer rod, tack it into the corrugation that will be inside the connector with some silicone and see if you can make a water seal with that. It will only have to cover 2/3 of the circumference on the bottom side of the joint.
Would the "PVC thinwall sewer/gutter drain pipe" route mean replacing the outlet, or would it connect to that? And if I would to the "poly-foam backer rod", what size would I need, 1/2 in or 5/8 in? – Joe Z Jul 29 '13 at 15:30
Yes, PVC will require you replace the Tee and outlet pipe as well as getting the adapters for the downspout and sump pump drain. There are corrugated to PVC adapters if the corrugated pipe run is extensive. And I'm guessing that 5/8 might be closer to what you need as there's a bit of slop in the connection on the corrugated pipe. – Fiasco Labs Jul 29 '13 at 15:36
