other Facts:
Window(s) size 3.5 feet* 5 feet (width)
Fan (2 nos.) Specifications Product page - specifications
Sweep size: 400 MM
RPM: 1280
Air Delivery: 75 CMM (What is the formula to convert CMM to CFM?)
Volume of the premise : 7200 Cubic Feet
High and Low Temperature day cycle (extreme during the year):
Month Wise Temperature Chart for the Location is available here
Summer: 45 Celcius - 29 Celcius (Comfort Target 22 Celcius)
Winter: 26 Celcius - 8 Celcius (Comfort Target 26 Celcius)
Purpose: To take the advantage of Temperature gradient between external temperature and internal temperature. Use fans during the time period when beneficial and put on Air Conditioner (Cooling and Heating) when compulsorily required to achieve last lag of the temperature target.
Note: Premise is a concrete building with no insulation, so its temperature follows the external temperature. (Heats up after external temperature goes higher and cools down after external temperature goes down)
(1) How effectively a single pedestal fan (blowing inward) can bring the outside air in the room if blades are 2 feet away from a fully open window (with the distant window of same size at the other end of the house is kept open)?
(2) How effectively a pedestal fan (blowing outward) can throw the air from the room out of window if blades are 1 foot away from a fully open window (with the distant window of same size at the other end of the house is kept open)?
or
(3) How effective will be two pedestal fans (one inward and one outward placed at distant fully open windows of the house) for displacing the indoor air with outside air?
If this question were to be answered by an air flow analysis professional they would probably be asking a whole slew of questions related to many other factors that you have not included here. The best this is probably to just try it out! And when doing that do consider why a window air conditioner is generally installed IN the window opening with a baffle to close up any extra open space. – Michael Karas Jul 28 '13 at 9:59
Fans blowing inwards near the floor bring in cool air, fans blowing outwards near the ceiling expel hot air. Your major goal is to provide a circular airflow that brings in cool air, puts it into contact with the interior contents to pull out the heat and then expel it. Cross flow where you pull air from the shaded side and push it out the sunny side works best. It would be more important if we knew the approximate volume attempting to be cooled, otherwise we have a lot of useless numbers. 75 CMM = 2650 CFM which is more than my powered gable vent moves. Invest in paper weights. – Fiasco Labs Jul 28 '13 at 21:01
@Fiasco Labs Sir,I've updated the question with some more details. What is the formula to convert CMM to CFM? – Optimight Jul 29 '13 at 1:09
Cubic meters per min to cubic feet per min -> m3/m * 35.32 = cfm – Fiasco Labs Jul 29 '13 at 1:31
And to figure air changes per hour -> (60 * cfm) / building volume = air changes per hour – Fiasco Labs Jul 29 '13 at 1:36
up vote 1 down vote accepted
While this doesn't directly answer your question, maybe you should consider a true window fan such as this one
window fan
It delivers 740 CFM, has a thermostat, is not too expensive (less than $50) and will be much more effective in ensuring the flow of outside air into the room. It's also reversible, so it can be used as an exhaust fan as well.
If you need more airflow, some models go up to nearly 3000 CFM (over 90 CMM) like this one.
