Take the 2-minute tour ×
I would like to have a bath with bath screen that is movable to the shorter edge of the bath. The problem is that I would also like to have my tap on the same shorter edge of the bath which would conflict with the screen. Of course when the screen is moved to the side the tap should be accessible so that I can wash something in the bath.
Currently I see two conceptual solutions to this problem:
  1. Use bath screen that contains many pieces so that all can be folded to fit between bath edge and tap.
  2. Make the screen go up when moving it to the side so that it is above the tap.
Somehow option two does appeal to me better, but are you aware of any components that would make it possible? Something that would make it possible to move a 10kg+ screen up and down (20cm) easily?
